What does it take to make my grid header has a separate vertical line between column header?
AND PLEASE DO NOT POINT ME TO A LINK. JUST GIVE ME A WORKING SAMPLE CODE RIGHT HERE.
Hello DQ ninh,
I know it may be a late response but here is what worked for me:
Under the ig_res directory you need to edit the ig_dataGrid.css file (it is located in the Default subdirectory unless you are using a custom style set)
Within ig_dataGrid.css, seek for these :
.igg_HeaderCaption --> it controls appearance of the header title area
tbody.igg_Item>tr>td --> it controls appearance of the data rows
tbody>tr.igg_Alt>td --> it controls appearance of the alternating data rows
you will need to add style properties in order to show separator lines, as in this sample code:
.igg_HeaderCaption{font-size: 10px;font-weight:normal;padding-left:4px;overflow: hidden;text-align:left;color:White;white-space:nowrap;border-left:1px; /*width of line separator*/border-left-style:solid; /*style of line separator*/border-color:black; /*color of line separator*/}
hope it will help!
regards,
Claudio
Hello DQ,
Have you been able to resolve the issue? If you need any further assistance, please feel free to contact me.
Sincerely,
Tsanna
Could you please clarify what do you mean by saying "separate vertical line between column header"? It would be great appreciated if you can provide me a screenshot that illustrates what you have in mind. Meanwhile please note that the grid's vertical lines between the column headers are set by grid's default styles. And if you want to modify them you may create your custom css classes or modify the default ones. Looking forward to hearing from you.
