I want to change the CaptionText of Header on WebDialogWindow, from client-side in a function BLOCKED SCRIPT
function GridViewData_Grid_AJAXResponse(sender, eventArgs) {//some code ...//.//.//.
var dialog = $find("WebDialogWindowMensaje");
dialog._header.setCaptionText('Error');
dialog.show();
But, I am getting an exception, Error: 'this._elems.7' is null or not an object...
I put a breakpoint and the exception is thrown on the line: dialog._header.setCaptionText('Error'); in the javascript function.
The version of NetAdvantage for ASP.Net is 11.1.20111.1006. In my page.aspx I have the following code:
<ig:WebDialogWindow ID="WebDialogWindowMensaje" runat="server" Height="200px" Width="500px" InitialLocation="Centered" Modal="True" Moveable="False" WindowState="Hidden"> <ContentPane BackColor="White"> <Template> <div style="padding: 20px; position: relative; text-align: justify;"> <div style="float: left; display: block; margin-right: 15px;"> <asp:Image ID="ImageMsg" runat="server" ImageUrl="" Height="50px" /> </div> <asp:Label ID="LblMensaje" runat="server" Text="PRUEBA"></asp:Label> <br /> <br /> <br /> <br /> <div style="float: right; display: block;"> <input id="BttnMsgOk" type="button" onclick="BttnMsgOk_onClick()" value="OK" style="background-color: #8AC4EA; color: #FFFFFF; font-size: small; font-weight: bold; width: 50px;" /> </div> </div> </Template> </ContentPane> <Header CaptionText="SomeText"> </Header> </ig:WebDialogWindow>
Is this error a bug of the WebDialogWindow object? or Am I making some wrong?
Thanks for your help.
Geovanny Domínguez
Hello Elizabeth,
Yeah!. I switched the setCaptionText and show() lines, now it works like I want.
That was all. Until next time!
Thanks.
Geovanny Domínguez.
Hello Geovanny,
I found this similar forum post that answers the question:
http://ko.infragistics.com/community/forums/t/6551.aspx
The dialog should be shown first. Try to switch the setCaptionText and show() lines. The linked post offers a couple of alternate solutions.
Elizabeth AlbertLocalization Engineer
Yes, your advice solves the error, thank you so much! But, I don't get to change the header text of the WebDialogWindow object. My JavaScript function:
var dialog = $find('<%= WebDialogWindowMensaje.ClientID %>'); dialog._header.setCaptionText("Error"); dialog.show();
How I can get this? May you help me, please?
You could get the ClientID of the dialog window in your JavaScript function.
Please let me know if you have any other questions.
