Hello All,
I want to Edit a particular Cell in Webdatagrid from Server side.
I want to do this in "OnInitializeRow" event of the Webdatagrid
Is there any event to Capture a particular cell and Set the property to Editable or non editable in InitialiseRow?
Please note that I am using webdatagrid not a ultrawebgrid hence unable to use the following syntax
e.Row.Cells[i].AllowEditing = Infragistics.WebUI.UltraWebGrid.AllowEditing .Yes;
e.Row.Cells[i].Style.BackColor = Drawing.Color.FromName("#E1E1E1")
Atleast I want to make the Row Editable or non editable from server side.
Can you please help me in this?
I am using Version 13.1 of CLR 4.0
Thanks in Advance for your Help.
Hello Parag,
I have noticed, that you have posted in the following forum thread too: http://ko.infragistics.com/community/forums/t/59560.aspx
If I understand correctly, what you want to achieve is to make a cell Editable based on a condition (let’s say a bool values column). Enable/Disable editing based on a bool condition, could be done by handling EnteringEditMode. I believe you tried using the EnteredEditMode, as mentioned in the other post. In the event handler a check could be made for every record versus a particular cell/condition if editing should be made or not. Regarding the implementation, you could consider using CheckBoxes or even a hidden column with bool values to be used for the checks.
“If you want an entire row/cell to not be editable, you will want to handle the client side EnteringEditMode (it cannot be done on a row/cell by row basis from the server). Here, the event args have access to the cell, and then you can get the row. You can determine if the row should not enter edit mode and then set_cancel(true) on the event args will stop entering of edit mode.”
Please refer to: http://ko.infragistics.com/community/forums/t/43128.aspx , if needed.Thank you for choosing Infragistics components!
I am using webdatagrid and want to make cell readonly/editable based on some condition from InitializeRow event through codebehind, please look in this issue.
Please, If you have another questions or need clarifying regarding this matter, please do not hesitate to contact me!
WebDataGrid supports configuring a whole column as ReadOnly from the code behind. Setting individual cells as ReadOnly requires handling the EnteringEditMode event and conditionally cancelling it based on the cell.
The following thread provides detailed information regarding this scenario and a sample illustrating how cell editing can be conditionally cancelled:
If you continue to experience any issues please do not hesitate to contact me.
