Has anyone used WebDataGrid with the Telerik Open Access ORM. It works well most of the time but when trying to use the filtering on the WebDataGrid no data was displayed for most of the filters. The only filter I could get to work was a datetime field when I set from... and entered the date.
Has anyone done this? Is there and easy fix?
Best RegardsGraham
Vivian
I am having problems on another matter which is also Infragistics webdatagrid not working the Telerik Open Access ORM. See http://ko.infragistics.com/my-account/support-case/CAS-120733-T9D3N3.
Hello Graham,
At the moment, I am not able to reproduce the behavior you described. If possible, please attach a copy of the aspx associated with the behavior. This way, we may investigate further.
If you have any questions, please let us know.
