20
Webdropdown.CurrentValue contains garbarge chars
Hi
I have a webdropdown with certain date values in it.
When I change the selected value and try to access it using .CurrentValue method it returns the value with certain control chars e.g. 2013%2f/07%2f/31. However, if the selection is not been changed the .CurrentValue contains the right value e.g. 2013/07/31
Why is this so? And how can I get the value in the selection after the selection is changed?
thanks
Adi
  • 8607
    Hello Adi,
    I made a test project and I get the control characters too.
    It seems like some encoding or decoding is done to the value.  To work around this, I first tried to use HttpUtility.HtmlEncode() or HttpUtility.HtmlDecode(), but it didn't make any change.
    Instead, I used String.Replace to get the expected result:
    String value = WebDropDown1.CurrentValue;
    value = value.Replace("%2F", "/");
    I have attached my sample.  I hope it helps.
    Elizabeth Albert
    Localization Engineer
    WebDropDownCurrentValue.zip
