Hi all,
I am using IG 2012 CLR3.5
I want to achieve an equivalent of UltraWebPanel using the existing provided controls, is WebExplorerBar limited to itemized listing or can it behanve like UltraWebPanel. Can anyone advice me?
Thank you,
Chinho
If you need any further assistance with this case, please let me know.
Hi Chinho,
You can achieve this using item templates in WebExplorerBar.
I am attaching a small sample, demonstrating how to add a button, a textbox and a label to the explorer bar group.
Please note that the version you are using is outdated and is no longer supported. I would suggest you to upgrade your product to a more recent version.
Let me know if you have any questions regarding the matter.
I will like to use WebExplorerBar like a panel, to contain labels, textboxes and a search button control.
The WebExplorerBar should be collapsible. Do you have a sample c#.net codes for this?
Thank you very much,
Yes, WebExplorerBar is the replacement control for WebPanel.
Can you tell me what exactly you want to achieve so I can try to point you in the right direction? Thanks.
