Build: 13.1.20131.2107
In my webdatagrid, I programmatically populate all the columns. I had multiline texteditorprovider for all text fields. Now I had a problem after I add the sorting behaviour. Whenever, I sort a column, it is working the first time. However, it is broken the second time. It generate the following exception.
Exception type: NullReferenceException Exception message: Object reference not set to an instance of an object. at Infragistics.Web.UI.GridControls.Sorting.AddHeaderImgToCaption(GridField column, SortDirection direction) at Infragistics.Web.UI.GridControls.Sorting.BehaviorEvents_PreRender(Object sender) at Infragistics.Web.UI.GridControls.GridBehaviorEvents.RenderingContentHandler.Invoke(Object sender) at Infragistics.Web.UI.GridControls.GridRenderer.RenderContents(HtmlTextWriter writer) at Infragistics.Web.UI.Framework.RunBot.HandleRenderContents(HtmlTextWriter writer, RendererBase renderer) at Infragistics.Web.UI.GridControls.WebDataGrid.GetRenderHTML() at Infragistics.Web.UI.GridControls.WebDataGrid.CallbackRender(CallbackObject callbackObject) at Infragistics.Web.UI.Framework.RunBot.CallbackRenderRecursive(CallbackObject callbackObject) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at Infragistics.Web.UI.Framework.RunBot.RenderPageCallBack(HtmlTextWriter writer, Control control) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Page.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
<The following code is used to generate the columns>
private void CreateColumns(DataTable theWholeTable, string tableName, int columnWidth) { //create editing core behaviour TableDetailGrid.Behaviors.CreateBehavior<Activation>(); TableDetailGrid.Behaviors.CreateBehavior<EditingCore>(); TableDetailGrid.Behaviors.EditingCore.AutoCRUD = false; TableDetailGrid.Behaviors.EditingCore.BatchUpdating = true; TableDetailGrid.Behaviors.EditingCore.Enabled = true; TableDetailGrid.Behaviors.EditingCore.Behaviors.CreateBehavior<CellEditing>(); //create an editor provider var textprovider = new TextEditorProvider(ID = "MultilineTextProvider"); textprovider.EditorControl.TextMode = TextBoxMode.MultiLine; TableDetailGrid.EditorProviders.Add(textprovider); //create RowAdding behaviour TableDetailGrid.Behaviors.EditingCore.Behaviors.Add( TableDetailGrid.Behaviors.EditingCore.Behaviors.CreateBehavior<RowAdding>()); TableDetailGrid.Behaviors.EditingCore.Behaviors.RowAdding.EditModeActions.EnableOnActive = true; TableDetailGrid.Behaviors.EditingCore.Behaviors.RowAdding.EditModeActions.MouseClick = EditMouseClickAction.Single; TableDetailGrid.Behaviors.EditingCore.Behaviors.RowAdding.Enabled = true; TableDetailGrid.Behaviors.EditingCore.Behaviors.RowAdding.Alignment = AddNewRowAlignment.Top; TableDetailGrid.Behaviors.EditingCore.Behaviors.RowAdding.AddNewRowClientEvents.EnteringEditMode = "AddRow_EnteringEditMode_CancelEventIfReadOnly"; //create RowDeleting behaviour TableDetailGrid.Behaviors.EditingCore.Behaviors.Add( TableDetailGrid.Behaviors.EditingCore.Behaviors.CreateBehavior<RowDeleting>()); TableDetailGrid.Behaviors.EditingCore.Behaviors.RowDeleting.Enabled = true; //get readonly column names var readOnlyColumnNames = GetReadOnlyColumnNamesByTable(tableName); //create sorting behaviour var sortingBehaviour = TableDetailGrid.Behaviors.CreateBehavior<Sorting>(); sortingBehaviour.SortingMode = SortingMode.Multi; foreach (DataColumn column in theWholeTable.Columns) { var theColumn = new BoundDataField(true); theColumn.Key = column.ColumnName; theColumn.Header.Text = column.Caption; theColumn.DataFieldName = column.ColumnName; theColumn.DataType = "System.String"; theColumn.Width = columnWidth; TableDetailGrid.Columns.Add(theColumn); //create column settings var settingColumn = new EditingColumnSetting(); settingColumn.ColumnKey = column.ColumnName; settingColumn.ReadOnly = (readOnlyColumnNames.Contains(column.ColumnName, StringComparer.InvariantCultureIgnoreCase) || string.Equals(column.ColumnName, Session["PrimaryKeyName"].ToString(), StringComparison.InvariantCultureIgnoreCase)); if (string.Equals(tableName, "dbo.CustomColumn", StringComparison.InvariantCultureIgnoreCase) && string.Equals(column.ColumnName, "SourceColumn", StringComparison.InvariantCultureIgnoreCase)) { settingColumn.EditorID = textprovider.ID; } ////create sorting column settings sortingBehaviour.SortedColumns.Add(TableDetailGrid.Columns[column.ColumnName], Infragistics.Web.UI.SortDirection.Ascending); TableDetailGrid.Behaviors.EditingCore.Behaviors.CellEditing.ColumnSettings.Add(settingColumn); } }
<This is the configuration of the webdatagrid in the aspx>
<ig:WebDataGrid ID="TableDetailGrid" runat="server" ClientIDMode="Static" Height="100%" Width="100%" EnableAjax="False" OnRowAdding="TableDetailGridRowAdding" OnRowUpdating="TableDetailGridRowUpdating" OnRowsDeleting="TableDetailGridRowDeleting"> <AjaxIndicator Location="MiddleCenter" /> <Behaviors> <%-- <ig:Paging PagerAppearance="Bottom" PageSize="10" Enabled="true" />--%> <ig:Filtering Alignment="Top" Visibility="Visible" Enabled="true" FilterType="ExcelStyleFilter"> </ig:Filtering> <ig:ColumnResizing Enabled="true"> <ColumnSettings> <ig:ColumnResizeSetting EnableResize="true" /> </ColumnSettings> </ig:ColumnResizing> <ig:Activation Enabled="True"/> <ig:Selection RowSelectType="Multiple" Enabled="true" ColumnSelectType="Single" CellClickAction="row" /> <ig:RowSelectors RowNumbering="true" Enabled="true" /> <ig:VirtualScrolling ScrollingMode="Virtual" DataFetchDelay="500" RowCacheFactor="3" ThresholdFactor="0.5" Enabled="true" /> </Behaviors> <EmptyRowsTemplate> <div id="divAttention" style="text-align: left;"> <br /> <img alt="Attention" src="/Images/attention.png" /> </div> </EmptyRowsTemplate> <ErrorTemplate> <div style="text-align: left"> <br /> <img alt="Error" src="/Images/error.png" /> <%= GetGlobalResourceObject("DataManager_English","ErrorTemplateMessage") %> </ErrorTemplate> </ig:WebDataGrid>
Can someone please help let me know why the textprovider does not work with the Sorting behaviour? Thank you so much.
Hello Andrew,
As the columns, updating behavior and the updating column settings are being created dynamically in this scenario, are they being recreated on each postback ? Does it make a difference in this case if they are instantiated only on the initial load ? A small sample application showing the issue in practice would be greatly appreciated and would allow me to examine this matter in more detail.
