1360
Grid Not Visible when Inside UserControl
I use a commercially available product to generate web-based database applications (CodeOnTime.com). This product produces standard ASPX web projects that are compatible with Visual Studio. Customising the application is done by adding UserControls (.ASCX) and placing custom code/web controls therein. I have found that WebDataGrids and WebHierarchical data grids do not display when placed within such a UserControl. (I can create a simple .ASPX project from scratch and it does work OK but when used in conjunction with generated applications it fails.) I have tried setting the grid's visibility etc but to no avail. if you use the browser inspection facility it is possible to manually switch off the visibility=hidden and display=none css tags and the grid becomes visible. But how could I do this reliably in code?
I have attached a link to a Visual Studio 12 project that exhibits this behaviour. Please edit the connectionString [SDS] in Web.Config to point to a copy of the Northwind database and run - The GridTest page shows as empty but it actually contains a WebDataGrid that remains hidden. As far as I can tell there are no JavaScript (or any other) errors whilst loading/running the project and I am at a loss to know how to fix this. (VS 2012, IG 13.1.2107 .net 4.5)
Please advise how to get this working.
I have an active licence for IG.Ultimate.
Kind regards,
Paul Shearing
