hi,
i had a 2011 version asp.net controls in my project.
so problem to load in new versions of browser, so please guide me how can i update my solution 2011 control to 2013?
Please guide me How can i do it?
Regards
Manish
I am checking about the progress of this issue. Please let me know If you need any further assistance on this.
It is possible that this won't work under IE10, because the NetAdvantage version that you are using was released before the mentioned browser.
I suggest you try at least v12.2 of NetAdvantage for ASP.NET with IE10, with manually changing the references.
If this still does not work for you I can try to troubleshoot a sample project of yours that reproduces the issue.
Clearly, the Version utility is not a good idea.
I got many projects in a solution under Source Safe. I just want to update 1 project and i need to extract the whole solution. Even if I do that, the update told me "Version updated", but nothing has changed !
My project references Infragistics2 10.2.20102.2129 and uses CLR 2.0.What version I need to use ? For now, nothing is working under IE 10.
I need a version for CLR 2.0 not 4.X.
Thanks.
http://ko.infragistics.com/community/forums/t/84551.aspx
If you are looking to upgrade from our old WebClient controls to our new ASP.NET tool set, this is a manual process including a new implementation of code and projects.
Since most likely you are trying to upgrade from 2011 ASP.NET controls to the same tool set in 2013, I can say that the version utility should be a good option. If it is not, you can do it manually by replacing the DLL libraries and functionalities that were depricated or changed or added for example.
i have updated une by one control manually in My application.
I got a solution befor use this.
