445
Checkbox column's inside webdatgrid posts back to server for several times
I have a webdatagrid with a checkbox column inside an ItemTemplate and a submit button as below
<Columns>
                <ig:TemplateDataField Key=" boolColumn">
                    <ItemTemplate>
                        <asp:CheckBox ID="CheckBox1" runat="server" AutoPostback="true" onCheckedChanged="CheckBox1_CheckedChanged"
                        Checked='<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "boolColumn")%>'>
                        </asp:CheckBox>
                    </ItemTemplate>
                    <Header Text="boolColumn" />
                </ig:TemplateDataField>
  </Columns>
<asp:button ID="btnSave" text="Save" runat="server" onClick="SaveGrid"/>
So now,I have a bunch of records with a checkbox column and a postback happens when I check/uncheck a checkbox, as intended. But the problem here is, if I have my checkbox selected on 2 rows,  the postback happens for 2 times and if 3 checkboxes on 3 rows are selected, then the postback happens 3 times. On top of it, when I click my save button, the checkbox's "CheckChanged" event gets fired first and then the save event gets fired.
Really wired. I dont understand why it happens, do you know why it is and have any solution for this?.
