Hello:
We are evaluating the WebDataGrid v13.1 control. We want to use it in our web app, but we have this issue: if a cell has a “19,65” value (note the comma separator as defined in Control Panel for floating point values), then:
In a similar, case:
Aspx:
<ig:WebDataGrid ID="WebDataGrid1" runat="server" Height="350px" Width="400px" AutoGenerateColumns="False"
DataKeyFields="id">
<Columns>
<ig:BoundDataField Key="id" DataFieldName="id" Header-Text="id">
<Header Text="id"></Header>
</ig:BoundDataField>
<ig:BoundDataField Key="Item" DataFieldName="Item" DataFormatString="{0:N2}" Header-Text="Item">
<Header Text="Item"></Header>
</Columns>
<EditorProviders>
<ig:NumericEditorProvider ID="WebDataGrid1_NumericEditorProvider1">
<EditorControl ClientIDMode="Predictable" DataMode="Decimal"
MaxDecimalPlaces="2">
</EditorControl>
</ig:NumericEditorProvider>
</EditorProviders>
<Behaviors>
<ig:Activation>
</ig:Activation>
<ig:EditingCore>
<ig:CellEditing>
<ColumnSettings>
<ig:EditingColumnSetting ColumnKey="id" ReadOnly="True" />
<ig:EditingColumnSetting ColumnKey="Item"
EditorID="WebDataGrid1_NumericEditorProvider1" />
</ColumnSettings>
</ig:CellEditing>
</Behaviors>
</ig:EditingCore>
</ig:WebDataGrid>
Hello Antonio,
I am still following your case. If you still have any concerns or questions I will be glad to help.
Thanks for you patience. In order to resolve this issue, you need to turn on Globalization in the ScriptManager to take care of the regional differences.
If you have any questions or concerns or if you need further assistance please let me know. Thank you for using our forum!
Hello Antonio, Thank you for posting in our forum! I've looked into your issue and have asked our development team to look further into it. In order to allow you to track the state of this issue I've opened a private case with number CAS-125517-Z1X0W1 . We'll continue communication trough the case.
