I am loading a UserControl that contains a WebMonthView dynamically into a WebTab on Page_Load. When I try to change the visible month using ActiveDayUTC, it does not change the month and uses the current month.
In my search for an answer, I found this: http://news.infragistics.com/forums/p/6158/26612.aspx
However I'm confused about passing the WebScheduleInfo to the control. I don't want the page to handle the WebScheduleInfo because it's used in multiple places across my application. Here is the code that I'm using on the Page_Load of the parent page:
Dim objTab As New Infragistics.WebUI.UltraWebTab.Tab(TabName) strUserControlURL = "~/UserControls/Learning/ucSessionMonthCalendar.ascx" objTab.ContentPane.UserControlUrl = strUserControlURL objSessionTabs.Tabs.Add(objTab)
How can this be resolved?
