We have recently installed and are now using Inf 13.2, but we've been using the Infragistics ASP controls since 9.1, I believe. I've fully upgraded the site I'm speaking of here from 11.1. Everything works fine in all browsers except IE11.
I'm putting this under the Webdatagrid forum, but there are actually 2 other problems with other Infragistics controls. I feel they are probably all related, though.
1) Webdatagrid - RowselectionChanged not firing, and the grid seems to be doing some weird behavior where it only allows you to select every odd row... But Rowselectionchanged doesn't even fire when you do that.
2) Webtab - Doesn't even render.
3) Input Controls (WebNumericEditor and WebCurrencyEditor) - Appearing, but extremely wide. Throwing all my pages off. They all seem to be showing around 150px-200px wide.
One strange caveat to my issue is that when I run the site from code (VS2010) in IE11, everything is perfect. Everything goes wrong (again, only in IE11) when I copy it to the web server and run from there. All pages are <!DOCTYPE HTML>. I've made sure that the web server has all the latest MS patches and everything. It's a Windows server 2008 R2 box running IIS 7.5.
I've dug all over the place and haven't found anyone with a similar problem, but I'm hoping that I'm just missing something silly here...
Thanks in advance,
Joe
Thanks for your reply............
I am stuck here because not finding any controls ....
Please confirm....
Thanks & Regards
Subhash Sharma
Since the forum thread is for different issue,
I am creating a private case for you CAS-139827-D5H6G0. I will update the case with details. Please refer to it.
Thanks for your reply................... :)..
I have not found any 11.1 controls into 14.1 version. so how can we use the existing one with ie 11 browser. Please see below the controls i am using in my application.. and Please suggest the Infragistic version for IE 11 with existing controls...
Hello Subhash, It is common practice to create a new forum thread with title - corresponding to the new issue, when the subject in the discussion changes from the original one. It is mainly because of tracking purposes. This helps finding similar issues more easily, when searching for previously posted threads in the forum.
Probably the easiest way to find the currently existing controls and their functionality is to browse through the online samples at: http://ko.infragistics.com/samples/aspnet/ In general, NetAdvantage version used for the samples browser is latest major released.
If details are required, the best source to refer is the official help documentation. All controls included in NetAdvantage 14.1 are listed here (including the functionality):http://help.infragistics.com/doc/ASPNET/2014.1/CLR4.0/?page=Web_Controls.html
All controls included in NetAdvantage 11.1 are listed here (including the functionality):http://help.infragistics.com/doc/ASPNET/2011.1/CLR4.0/?page=Web_Controls.html
Thanks really helpful....:)
One more question could you please confirm the controls supported to 13.1 and above like(13.1, 13.2, 14.1) dlls.
a) Inrfagistic - WebPanel
b) Infragistic - WebDateChooser
c) Infragistic - WebMaskEdit
d) Infragistic - UltraWebGrid
All the above controls I am using into my application using 11.1 infragistic dll and using come client side event and row selection event . I need to confirm all above given controls also supported by 14.1 and all client side event also .
Thanks and Regards
