I am trying to add Session State to my app. I want to store session in SQL. One item that is being saved to session is the webdatagrid sorting information. When I attempt to serialize my object right before sending it to session I get this error:
Type 'Infragistics.Web.UI.GridControls.SortedColumnInfoCollection' in Assembly 'Infragistics4.Web.v13.1, Version=13.1.20131.1012, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' is not marked as serializable.
I am trying to save the SortedColumnInfoCollection to session so I can reset the grid when the user returns to it. There is no inner exception. The object that I store this information is marked a Serializalbe and it inherts ISerializable. If I take out the SortedColumnInfoCollection, it works. But I want to save that information or I will have to remove that feature from the users. And I would rather not do that. Does anyone know how to get around this?
Here is a copy of the Object that I am trying to Serialize.
[Serializable] public class GridSettingsHolder : ISerializable { protected SortedColumnInfoCollection _columnSortInfo; protected ColumnFilters _columnFilters;
public GridSettingsHolder() { }
public Infragistics.Web.UI.GridControls.SortedColumnInfoCollection ColumnSortingInfo { get { return _columnSortInfo; } set { _columnSortInfo = value; } }
public Infragistics.Web.UI.GridControls.ColumnFilters ColumnFilters { get { return _columnFilters; } set { _columnFilters = value; } }
public void GetObjectData(SerializationInfo info, StreamingContext context) { info.AddValue("ColumnSortingInfo", this._columnSortInfo); info.AddValue("ColumnFilters", this._columnFilters); }
public GridSettingsHolder(SerializationInfo info, StreamingContext ctxt) {
this._columnSortInfo = (SortedColumnInfoCollection)info.GetValue("ColumnSortingInfo", typeof(SortedColumnInfoCollection)); this._columnFilters = (ColumnFilters)info.GetValue("ColumnFilters", typeof(ColumnFilters)); } }
I'm just checking if you have any further questions.
SortedColumnInfoCollection class is not serializable and that's why you are getting the exception when you are using it as a property of Serializable class. I would suggest you to have a look at our Persistance framework that can help to persist control state: http://help.infragistics.com/Help/Doc/ASPNET/2013.2/CLR4.0/html/PersistenceFramework_About_Persistence_Framework.html.
Here you can find demo samples:
http://ko.infragistics.com/products/aspnet/persistence-framework/
Hope this helps.
