I want to add web schedular within webdailogwindow from code vb.net, can please suggest how can we achieve this,
Hi troy.
As is mentioned in my previous post, regarding one issue i am facing once after setting Activeday in dayview scheduler calender, isssue is that
if i set active from VB code to display selected dates from list it will display set date in day calender scheduler. but after do this i am not able to move to next date by using calender next arrow .
myWebDayView.WebScheduleInfo.ActiveDayUtc = Parse("2010-07-10") this is the way i am setting required date to be displayed. I am faing this problem only in day view calender. Once after even if i click on go to previous date its going 2-days back like if current set date is 10th July if i click on previous arrow its going to 8th july. same way if i click on next day arrow in calender its not changing date. Please suggest to resolve this issue.
I am using Infragistics35.Web.v12.2 and Version=12.2.20122.2202
Hi Ganesh,
Please let me know if you need any additional assistance regarding this matter.
To achieve this objective there are two resources I can point you towards that should help you to add a WebSchedule created in code to the WebDialogWindow (WDW):
1. ) This documentation walks you through creating the WebSchedule in code. It shows the code in VB (and C#): http://help.infragistics.com/doc/ASPNET/2013.2/CLR4.0/?page=WebSchedule_Creating_WebSchedule_Controls_Using_Code.html
2) Once the WebSchedule is created in code, you can add it to the WDW content pane collection (WebDialogWindow1.ContentPane.Controls.Add(lb);). This forum post shows doing it with a label and button, but the same applies for adding the WebSchedule to the collection: http://ko.infragistics.com/community/forums/p/23587/86406.aspx
