20
Could not load file or assembly 'Infragistics4.Web.v13.2' or one of its dependencies. This assembly is built by a runtime newer than the currently loaded runtime and cannot be loaded.
I get this error:  Could not load file or assembly 'Infragistics4.Web.v13.2' or one of its dependencies. This assembly is built by a runtime newer than the currently loaded runtime and cannot be loaded.
What am I doing wrong?  Did I miss to add something?  I'm running vs2008 .net 3.5
Copied "Infragistics4.Web.v13.2.dll" to the bin directory.
I added these to my web.config:  (Just pasted the parts I added)
<configuration>
<configSections>
<section name="infragistics.web" type="System.Configuration.SingleTagSectionHandler,System, Version=1.0.3300.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<pages theme="Default">
<controls>
<add tagPrefix="ig" namespace="Infragistics.Web.UI" assembly="Infragistics4.Web.v13.2" />
<add tagPrefix="ig" namespace="Infragistics.Web.UI.ListControls" assembly="Infragistics4.Web.v13.2" />
<add tagPrefix="ig" namespace="Infragistics.Web.UI.DataSourceControls" assembly="Infragistics4.Web.v13.2" />
<add tagPrefix="ig" namespace="Infragistics.Web.UI.GridControls" assembly="Infragistics4.Web.v13.2" />
<add tagPrefix="ig" namespace="Infragistics.Web.UI.NavigationControls" assembly="Infragistics4.Web.v13.2" />
<compilation debug="true">
<assemblies>
<add assembly="Infragistics4.Web.v13.2, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" />
<add assembly="Infragistics4.WebUI.Shared.v13.2, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" />
