Our application uses a lot of javascript to calculate values before saving them. In a couple of cases, I set the initial value of a WebPercentEditor to the result of a javascript calculation. I discovered that when the value assigned has more digits than the value displayed, there are two issues regarding rounding.
1) The value assigned is being truncated, not rounded. (We desire rounding anything up where the first hidden/truncated digit is 5 or higher.) I am guessing set_value(x) is acting as if the value of x is being typed in. Thus any digits after those displayed are ignored. (Although I do not know for certain if this is the cause.)
So for a WebPercentEditor with MinDecimalPlaces = 4, DisplayFactor = 100, DataMode = Double:
ctrl.set_value(0.15529855694106875); should show 15.5299 %. It currently shows 15.5298 %. Although intriguingly I notice the mouse-over tooltip correctly shows 15.5299 %.
2) If DisplayFactor is 100 (the default, and our desired value) and again MinDecimalPlaces = 4,
ctrl.set_value(0.000298); should show 0.0298 %. It currently shows 0.0297 %. (As does the mouse-over.)
I think this is because, due to javascript’s limitations, after the following calculation is done
var temp = 0.000298 * 100;
temp has a value of 0.029799999999999996.
This is probably what the WebPercentEditor is doing internally before truncating the digits.
I’ve come up with a workaround for us to assign values that assigns and rounds values for us as desired. It is shown below. But ideally the client-side set_value() method (or maybe a set_number() method) would do this for us. Or is there some combination of settings I am missing that would cause the desired behavior?
//Round a number more cleanly, with less floating point precision errors from Javascript
function roundNumber(number, precision) {
precision = Math.abs(parseInt(precision)) || 0;
var multiplier = Math.pow(10, precision);
return (Math.round(number * multiplier) / multiplier);
//Set the value of a WebPercentEditor or WebNumericEditor so that it will round and display appropriately.
//Replace calls of "ctrl.set_value(val);" with "setEditorNumber(ctrl, val)" when rounding might be an issue.
function setEditorNumber(ctrl, val) {
var decimals = ctrl.get_minDecimals();
if (ctrl._factor == 100) {
decimals += 2;
//The buffer is a small number to add before rounding to prevent something like 0.000298 to become
//something like 0.029799999999999996 when the control changes to % and then 0.0297 % when it truncates
//(assuming 4 decimal places displayed).
var buffer = Math.pow(10, -(decimals + 1));
ctrl.set_value(roundNumber(val, decimals) + buffer);
Anyway, thanks in advance.
Trevor
Hello Trevor,
Thank you for your posts !
I have investigated this matter and logged 2 development issues for further review by our engineers - 164326 and 164327. I have also created 2 support tickets for you in order to keep you posted of the status of these items - CAS-131388-Q6Q5V5 and CAS-131697-T7R3H1, and will contact you through them with more information shortly.
On a related note, I see that numbers pasted into the WebNumericEditor and WebPercentEditor are also being truncated to the specified number of digits instead of rounded to the specified number of digits. This is also different than how the old WebNumericEdit and WebPercentEdit controls worked. Any suggestions if the old behavior is not required by our clients? Any chance this could be restored in a service release or future version? (Perhaps with a property to specify the preferred behavior?)
Correction to my workaround code to fix rounding negative numbers:
//Round a number more cleanly, with less floating point precision errors from Javascript function roundNumber(number, precision) {
//Replace calls of "ctrl.set_value(val);" with "setEditorNumber(ctrl, val)" when rounding might be an issue. function setEditorNumber(ctrl, val) {
if (val < 0) {
ctrl.set_value(roundNumber(val, decimals) - buffer);
else {
