We are facing an issue in WebHTMLEditor in IE 11.
The control does not set the actual height provided in the ASPX page and in Code behind
Previously, We had used 11.1 and there is no issue in it after upgrading to 13.2 this issue occurs.
We are using the version 13.2 hotfix 2028.
Please find the attached sample file and suggest.
Thanks in advance.
Hi Prabha,
we are migrating the our asp.net application to support in IE11 . We have planned change the following controls
1) Webdatagrid
2) Webdatepicker
3) WebhtmlEditor
We are able to manage the changes for webdatagrid and webdatepicker in the Infragistics version 12.1.20121.2236. We tried same for the html editor. The Forecolor,backcolor. not able to highlight in the selected font and font-size with that and some more issues we found.
As per supported environments for IE11 is 13.x and more. We planned to use latest the versions The html editor is works fine in the 14.2.20142.1028 ,13.2.20132.2294.
But the in the webdatagrid,OnCommand event, Check selection,radiobutton and findcontrol is not working completely.
http://ko.infragistics.com/community/forums/t/95410.aspx this is resolved the onCommand event
http://ko.infragistics.com/community/forums/t/95026.aspx. - In this link it does not solve my problem, Check selection,radiobutton and findcontrol is not working completely.
Please help me proceed.
Thanks a lot for the information. I have check this release and it works fine.
Thanks for the support and continuous follow up.
With Regards,
Giridhar JG.
Hello Sphinx,
Issue "164051: Editor Height is not calculated correctly and consistently" has been addressed in service release versions ASP.NET_13.1.20131.2271, ASP.NET_13.2.20132.2109, ASP.NET_14.1.20141.1015.
The following additional notes have been provided regarding this issue:
This service release is now available under your account at the Infragistics Website. To download the service release, log in to ‘Account’ and select ‘Keys & Downloads’. Select the appropriate tab for this product; then the license key. The available service releases (Hot Fixes) should now be listed on the page.
Please let me know if you have any further questions regarding this matter.
I have investigated your issue and, I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 164361. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
I will leave this case open and update you with any new information after the review. You can also continue to send updates to this case at any .
