I have a column that assigns a calulation and it works great.
What I want to be able to do is click a button that says "Clear calculations".
Is there a way to clear the contents of a calculated column?
You would need to remove the calculation from the column. Clearing the Calculation settings on the column should do the trick.
-Tony
