Hello there,I'm using a "DropDownProvider" as my EditorProvider in my WebDataGrid. I understand that only one Dropdown would be generated for the Column for which the DropdownProvider gets assigned.Here my need is, I would like to bind the DropDown value based on some condition which may vary for every row. I thought of accompolishing this by finding the DropDownProvider of each row and assign the value, in the "InitializeRow" event of the grid, but end up with no possibilities.Kindly suggest me a workaround this.
Hello Nagaraj ,
Indeed when using editor providers a single instance of the editor is created and used for all cell that belong to the specified column.
If you prefer each cell from the column to have a separate instance of a control you can create a TemplateDataField and set in its ItemTemplate a WebDropDown control.
For example:
<ig:TemplateDataField Key="key">
<ItemTemplate>
<ig:WebDropDown ID="WebDropDown1" runat="server" Width="200px">
</ig:WebDropDown>
</ItemTemplate>
</ig:TemplateDataField>
In that case you can get the specific instances of WebDropDown controls for a specific row for example: webDataGrid.Rows[0].Item[0].FindControl(“WebDropDown1”)
And set a specific value to each.
Let me know if you have any questions .
Best Regards,
Maya Kirova
Developer Support Engineer II
Infragistics, Inc.
