I have web splitter with 3 panes as shown in image.when i collapse 1st pane the width of 3rd pane changes you can see this in firstpanecollapse image.My requirement is not to change 3rd panes width not even flicker it.When i collapse 1st pane the width of middle pane should change and it should expand from left side not from right side and collapse 3 rd pane the middle pane should expand to right side not from left in this case the 1st pane should be in fixed position.Is it possible to achieve it??
size of each pane at start
pane1-25%
pane2-50%
pane3-25%
Hi Prajakta,
I by accident replied to wrong post. Please see http://ko.infragistics.com/community/forums/t/87679.aspx
fisrtpanecollapse image
