I have a repeater control which on clicking opens a web data menu which opens items as primary menu. The menu opened in a div with CSS set to "overflow:hidden", which opens the primary menu in the panel. When CSS (overflow:hidden) is removed, the primary menu creates an extra space below the page footer.
The code snippet is given below. The screenshots are also attached for further clarification.
<div id="leftpanel_bg" class="leftpanel_bg" style="display:none;"></div> <div id="leftPanel" class="leftPanel"> <div id="navigation" class="leftPanelContent nodisplay"> <asp:Repeater ID="rptParent" runat="server" OnItemDataBound="rptParent_ItemDataBound"> <HeaderTemplate> <table width="100%" border="0" cellpadding="0" cellspacing="0" > </HeaderTemplate> <ItemTemplate> <tr> <td> <div class="left-menuspacer"> </div> </td> </tr> <tr> <td class="left-menurow"> <div class="left-menuplus"> <asp:HiddenField ID="hdnFldToggleState" runat="server" Value="1" /> <asp:HiddenField ID="hdnEmployeeParentId" runat="server" Value='<%#Eval("EmpID") %>' /> <asp:HiddenField ID="hdnEmployeeParentName" runat="server" Value='<%#Eval("Name") %>' /> <asp:HiddenField ID="hdnLastFeedbackDate" runat="server" Value='<%#Eval("LastFeedbackDate")%>' /> <asp:ImageButton ID="imgBtnNode" runat="server" ImageUrl="~/TalentfirstV3/Images/icon_plus.png" OnClientClick="ToggleChildItem()" /> </div> <div style="float: left;"> <ig:WebDataMenu runat="server" ID="ContextMenuParent" IsContextMenu="false" EnableScrolling="false" ActivateOnHover="false" CloseMenuOnClick="false" EnableExpandOnClick="false"> <ClientEvents ItemSelecting="WebDataMenu1Client_ItemSelecting" /> <%--<ClientEvents ItemClick="ContextMenu_ItemClick" />--%> <Items> <ig:DataMenuItem Key="TopItem" TemplateId="ParentMenu"> <Items> <ig:DataMenuItem Text="Provide Feedback" Key="ProvideFeedBack" CssClass="dtMenuParentitem"> <Items> <ig:DataMenuItem Key="Reports" /> <ig:DataMenuItem Key="ActionRequired" /> <ig:DataMenuItem Key="QuickFeedback" /> <ig:DataMenuItem Key="DistanceCoaching" /> </Items> </ig:DataMenuItem> <ig:DataMenuItem Text="Assign Training" Key="AssignTraining" CssClass="dtMenuParentitem" /> <ig:DataMenuItem Text="Assess Proficiency" Key="AssessProficiency" CssClass="dtMenuParentitem" /> <ig:DataMenuItem Text="Request Self-Assessment" Key="RequestAssessment" CssClass="dtMenuParentitem" /> <ig:DataMenuItem Text="Request Multi-rater Feedback" Key="RequestMultiFeedback" CssClass="dtMenuParentitem" /> <ig:DataMenuItem Text="Review Goals" Key="ReviewGoals" CssClass="dtMenuParentitem" /> </Items> </ig:DataMenuItem> </Items> <Templates> <ig:ItemTemplate TemplateID="ParentMenu"> <Template> <div class="left-menuimage"> <asp:Image ID="imgEmployee" runat="server" /> </div> <div class="left-menutext" style="width: 250px; word-wrap: break-word;"> <span class="LftPnlName"> <asp:Label ID="lblName" runat="server"></asp:Label> </span><span class="LftPnlfeedback">Last Feedback: <asp:Label ID="lblfeedbackDate" runat="server"></asp:Label> </span> </div> </Template> </ig:ItemTemplate> </Templates> </ig:WebDataMenu> </div> </td></tr>
</ItemTemplate> <FooterTemplate> </table> </FooterTemplate> </asp:Repeater> </div> <div class="HNewsBtn"> <img runat="server" id="newsPlusClick" src="~/TalentFirstv3/images/my_team_col.png" title="My Team" alt="My Team" /> </div> </div>
The zip file containing the screenshots of my probelm.
Thanks.
I am still following your case. Have you been able to resolve your issue?
Hi Atinder,
Thanks for the link, but I will have to see your code. I could not find what is causing the issue from looking into the page you provided. Please share a small sample reproducing the behavior you are experiencing and I will be glad to look at it.
Sorry for not following you for the problem. I was busy in some other tasks. So, as you requested I have created a running sample which demonstrates the problem.
You can follow the below for the replication of the problem.
http://test.talentfirst.com/TalentFirst/TalentFirstV3/TestPage/ConnectDashboard.aspx
Let me know if you have any issue.
I'm just checking if you already managed to resolve your issue.
Hello Atinder,
I'm not sure what is causing this behavior. I see you have applied custom styles to the menu which may have affected the page layout somehow. I would need a running sample that reproduces the issue, in order to be able to investigate it further. Please provide a small website that demonstrates this behavior and I will be glad to look at it.
