Hi guys
I'm deploying my asp.Net 4.0 on the host 1and1.com...
Everything works fine except for asp pages where there is :
WebDialogWindow
and pages where there is a WebTab
I could use workaround to avoid this error by not using these two controls and change my pages but I would like to keep the user using these controls.
One my server (IIS 8), everything is working fine... It's really a matter of the hosting service.
I've seen couple of thread about TabRender and WebDialog having trouble but YOU NEVER POST A CORRECT ANSWER TO SOLVE THIS PROBLEM...
So, could you tell me what to do in order to provide an answer...
I don't want to push you to hard but my site is about to be used by lots of people, and I really appreciate to know as fast as possible if I need to use my workaround (remove these controls and create new pages - f..k...) or no by listening and applying a good solution...
For the webTab page, if I display the source code, I get this for error...
Hello Nicolas,
Thank you for your reply.
Please feel free to contact me if you have any further questions regarding this matter.
Ok thanks
I already knew these posts...
Trust level wasn't allowed by the provider...
So, I just changed my pages to make it works !
Have you tried the approaches suggested at:
http://ko.infragistics.com/community/forums/p/66068/439726.aspx#439726
If the suggested modifications do not resolve the issue, it is likely due to the settings set by the hosting service, some of which cannot be overridden:
http://forums.asp.net/t/1458917.aspx
Please do not hesitate to contact me with any questions.
