710
WebExplorerBar structure and accessing its controls in code behind
Hi, I am migrating from 11.1 to 13.2 and I have a page that have plenty of controls, among them, WebTabs with WebExplorerBars that have DataGrids inside and other asp controls.
For example, here's one WebExplorerBar:
<ignav:WebExplorerBar CssClass="panelBackground" ID="wpExpensesCodes" Height="275px" Width="645px" runat="server">
<Templates>
<igtbl:WebDataGrid ShowHeader="true" AutoGenerateColumns="false" ID="uwgRelationsExpensesCodes" runat="server" Width="643px" Height="220px">
<Columns>
<igtbl:BoundDataField Key="ExpenseId" DataFieldName="ExpenseId" Hidden="true">
</igtbl:BoundDataField>
<igtbl:BoundDataField Key="Name" DataFieldName="Name" Width="530px">
<Header Text="Name">
</Header>
<igtbl:BoundDataField CssClass="cellGridStyle" Key="MenuPosition" DataType="System.Int16" DataFieldName="MenuPosition"
Width="90px">
<Header Text="Menu Position">
</Header>
</Columns>
<Behaviors>
<igtbl:RowSelectors Enabled="false"></igtbl:RowSelectors>
<igtbl:Selection CellClickAction="Row" CellSelectType="Single"></igtbl:Selection>
<igtbl:ColumnFixing Enabled="true"></igtbl:ColumnFixing>
<igtbl:EditingCore>
<Behaviors>
<igtbl:RowAdding Enabled="true"></igtbl:RowAdding>
<igtbl:CellEditing>
<ColumnSettings>
<igtbl:EditingColumnSetting ColumnKey="MenuPosition" ReadOnly="false" />
<igtbl:EditingColumnSetting ColumnKey="ExpenseId" ReadOnly="true" />
<igtbl:EditingColumnSetting ColumnKey="Name" ReadOnly="true" />
</ColumnSettings>
</igtbl:CellEditing>
</Behaviors>
</igtbl:EditingCore>
</Behaviors>
</igtbl:WebDataGrid>
<div style="height: 5px;">
</div>
<asp:DropDownList ID="cmbRelationsExpensesCodes" runat="server">
</asp:DropDownList>
<asp:Button ID="btnRelationsExpensesCodesAdd" OnClick="btnRelationsExpensesCodesAdd_Click"
Text="Add" Width="80px" runat="server" />
<asp:Button ID="btnRelationsExpensesCodesDelete" OnClick="btnRelationsExpensesCodesDelete_Click"
Text="Remove" Width="80px" runat="server" />
</Templates>
</ignav:WebExplorerBar>
And I access its controls in the code-behind, and it's compiling perfectly
but once I launch the application I am getting this error:
Infragistics.Web.UI.ItemTemplateCollection must have items of type 'Infragistics.Web.UI.ItemTemplate'. 'igtbl:WebDataGrid' is of type 'Infragistics.Web.UI.GridControls.WebDataGrid'.
STEP 2:
taking that error into consideration, I tried adding the ItemTemplate like this:
<Templates>
<ig:ItemTemplate>
<Template>
<Columns>
</Header>
Width="90px">
</Header>
</Columns>
<Behaviors>
<igtbl:EditingCore>
<Behaviors>
<igtbl:CellEditing>
<ColumnSettings>
</ColumnSettings>
</Behaviors>
</Behaviors>
</div>
</asp:DropDownList>
</Template>
</ig:ItemTemplate>
</Templates>
but now my application is not compiling because I can't find the controls within this WebExplorer, for instance "cmbRelationsExpensesCodes"
what am I doing wrong?
than you!
  • 7499
    Verified Answer
    Hello Nicole,
    The step 2 is the right way to add a template inside the WebExplorerBar, but you cannot access the controls inside the template using the ID. To access the webdatagrid inside the webexplorerbar use the following code
    WebDataGrid wdd = (WebDataGrid)this.WebExplorerBar2.Groups[0].Items[0].FindControl("WebDataGrid1") ;
    Please let me know if you have any questions
