Scheduler control we saw in your site day scheduler control in drag and drop option is there but month and week view in drag and drop option is there or not.
Thanks & Regards
Anand
Try this sample (online or installed locally as part of the SDK),http://samples.infragistics.com/2008.2/webfeaturebrowser/WebSchedule/PropertiesSample/WebDayViewGeneralProperties.aspx
Add an activity by double-clicking on the day view area, then after it shows up mouse over by its left side where the cursor changes and drag it up/down. Note that the EnableActivityMoving property is set to true.
If you mouse over the top or bottom edge, the cursor changes and you can drag the start time up/down or the end time up/down. For this feature, the EnableActivityResizing property is set to true.
Hi, there!
I'm trying to make drag and drop of appointment in WebDayView control but it cannot magane to work.
Can somebody give me an example what I should do to be able to drag and drop appointments to change their starting and ending hour.
I need to be done for WebWeekView and WebMonthView, but I'll write this down like a RequestFeature.
Regards, Iva
Dragging appointments within a day (for instance to another hour) in WebDayView is supported, but drag-and-drop between days (i.e., the only resolution visible on weekly or monthly schedules) is not supported.
If you would like to see this feature, please register your interest in it at http://devcenter.infragistics.com/Protected/RequestFeature.aspx
