125
Tooltip problem in a Stacked Column chart
Hello there,
I have a fairly straightforward Stacked Column chart. Everything displays correctly, other than the tool tips. I want the each column in a stack to display its own value as opposed to the accumulated value. The data for the columns in a stack are percentages, therefore the top column always displays a 100.
 So, I have two questions. Is it possible to display percentages in a Stacked Column chart rather than numbers? If not, what is the best way to have the tooltips display proper values for each column in a stack?
I created this chart through the Chart Wizard, so I have no custom code that I can add stuff to.
 Thanks for any help
