I have not been able to find a working example of hiding the check boxes on the WebDataTree. We are using version 11.1 build 2238.
I would like to hide the check boxes of the items that have children. I can do this this with jquery but I am unable to use jquery on this project. I saw this example http://ko.infragistics.com/community/forums/t/36625.aspx but I am not able to get it working. Does this require a reference to the infragistics JavaScript files to get the methods used in the example to work correctly.
Thank you very much that worked perfectly.
Hello John ,
It doesn’t require any additional scripts to be added. However make sure you set the init() method is hooked to the Initialize client side event of the WebDataTree.
For example:
<ClientEvents Initialize="init" />
Otherwise the code won’t be executed.
I’ve attached a sample for your reference. Please refer to it and let me know if you have any questions.
Best Regards,
Maya Kirova
Developer Support Engineer II
Infragistics, Inc.
