60
Registering Assemblies
This might be a little bit more of a ASP.NET question than a specific Infragistics question but here goes.
Currently we seem to be regisitering the assemblies in two places. Firstly in the web.config as follows:
<add assembly="Infragistics2.WebUI.WebHtmlEditor.v7.2, Version=7.2.20072.1075,
Secondly we register then on the page/control:
<%@ Register Assembly="Infragistics2.WebUI.WebDateChooser.v7.2, Version=7.2.20072.1075, Culture=neutral,
Our problem is if we change the infragistrics version we have to change many references throughtout the code. Is there a way to just register the assemblies in the web.config.
I think this just need someone to clear up my thinking of registering .NET assemblies.
Chris
  • 10880
    Our samples use the method you speak of where you place the register tags in the web.config. You can find this web.config in "C:\Users\Public\Documents\Infragistics\NetAdvantage for .NET 2008 Vol. 2 CLR 2.0\Samples\ASP.NET" if you installed the SDK.  Here is a code snippet for the syntax.
    <configuration>
    <system.web>
           <pages>
          <controls>
            <add tagPrefix="igexcel" namespace="Infragistics.Excel" assembly="Infragistics2.Excel.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB" />
    On side note there are many ways to upgrade besides a manual process.  We provide two utilities, Project Upgrade Add-In and Project Upgrade Utility, that automate this process.  More information for upgrading can be found here:
    http://help.infragistics.com/Help/NetAdvantage/NET/2008.2/CLR2.0/html/Web_Upgrading_Your_ASP_NET_Projects.html
