I have a lot of WebDialogWindows in my webpage and several of them are giving me a weird display issue. See the attached document for a screenshot and code for the window. I colored the background red so that you can easily see what is causing the problem. The background apparently extends below the border and into the dialog window. Without the added color, it would just display as white space in the body and on top of the border of the window.
It doesn't happen all the time, and it seems to only do this when I right-click the page and click 'view in browser(internet explorer(IE10))' If I run the program in debug mode, it displays correctly. If I right-click the page and click 'view in browser(internet explorer)', then copy/paste the path into another browser window, it will display correctly. At this point, it seems to be a display bug in test mode only.
Hello Jesse,
I am just following up and see if you have any questions.
Thank you for the information.
Currently, IE10 is not supported in NetAdvantage 10.3. IE10 is supported in NetAdvantage 12.2 and later versions. You may upgrade or you may keep the application set to run in IE9.
For more information on our supported environments, you may refer to the documentation below:
http://ko.infragistics.com/help/supported-environments/
If you have any questions, please let me know as well.
VB2012, IG webDialogWindow version 10.3
Thank you for the screenshot. Please let me know the version and build you are using.
Done.
