Hi everyone,
I'm trying to get on client side (javascript function) the number of the page that the user selected on the grid.
I create the Paging Client Side Event and this javascript function has only a sender parameter but I can't find how to get which #page the user press to move. I need this because I need to move another grid to another page too.
Thanks a lot !!!
Gustavo.-
It's quite working but when I change my page, I am getting blank grid. What needs to be implemented there. Thanks.
Hello Gustavo,
Please let me know if you need further assistance with this issue and I will be glad to help.
Thank you for posting in our forums!
As you mention there is only a sender argument, I am assuming you are handling the PageIndexChanged event. The sender argument is the grid, which means you can access the Paging behavior from it. Also, since this is the PageIndexChangED event, the Paging behavior is storing the new page index.
You can use the following code to get the page index:
var newPageIndex = sender.get_behaviors().get_paging().get_pageIndex();
Or if you happen to be handling the PageIndexChangING event, there should be a second argument, eventArgs. If you are using the PageIndexChanging event and do not see the eventArgs parameter, you can add eventArgs to the signature. And you can use the following code to get the new page index:
var newPageIndex = eventArgs.get_newPageIndex();
If you have any further questions or concerns with this, please let me know.
