Just downloaded and attempted to run Infragistics_Ultimate_20142.exe. After entering the product key and pressing "NEXT" it crashed with the error below. I'm using Windows 7 and all previous versions have installed fine.
************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at Infragistics.Wrapper.Interface.UI.User_Controls.TotalDiskSpaceGrid.UpdateDisplay(IgDriveRequirementInfo diskSpace) at Infragistics.Wrapper.Interface.UI.ProductSelectionDialog.UpdateTotalsLabels() at Infragistics.Wrapper.Interface.UI.ProductSelectionDialog.psc_CheckStateChanged(Object sender, ProductCheckedControlEventArgs e) at Infragistics.Wrapper.Interface.UI.User_Controls.ProductSelectionControl.OnCheckStateChanged(ProductCheckedControlEventArgs e) at Infragistics.Wrapper.Interface.UI.User_Controls.ProductSelectionControl.chkProduct_AfterCheckStateChanged(Object sender, EventArgs e) at Infragistics.Win.UltraWinEditors.UltraCheckEditor.AfterCheckChangedHelper(CheckState newVal, EventArgs e) at Infragistics.Win.UltraWinEditors.UltraCheckEditor.set_CheckState(CheckState value) at Infragistics.Wrapper.Interface.UI.User_Controls.ProductSelectionControl.SetCheckedProductsState() at Infragistics.Wrapper.Interface.UI.ProductSelectionDialog.AddProducts(String productSetCategory, List`1 productsToAdd) at Infragistics.Wrapper.Interface.UI.ProductSelectionDialog.BuildProductSelectionTable() at Infragistics.Wrapper.Interface.UI.ProductSelectionDialog.InitializeUI() at Infragistics.Wrapper.Interface.UI.ValidateKey.GoToSelectionScreen() at Infragistics.Wrapper.Interface.UI.ValidateKey.PerformNextButtonClick() at Infragistics.Wrapper.Interface.UI.IgBaseForm.btnNext_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at Infragistics.Win.Misc.UltraButtonBase.OnClick(EventArgs e) at Infragistics.Win.Misc.UltraButton.OnMouseUp(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Hello all,
I just want to let you know a fix has being released. To download the release, log in to ‘Account’ and select ‘Keys & Downloads’. Select the appropriate tab for this product then the license key. The volume release packages should now be listed on the page and available for download.
Hello Marcus,
This has being determined to be a dev issue and it will soon be fixed. You could track the progress of this issue trough the case CAS-145377-G1G1B2.
