888
BoundDataField show alternative text to value from datasource
I have been able to properly show the label for a boolean field to show "Yes" or "No" instead of true or false.  I did this by adding a DropDownProvider for the column and created a datasource that shows correlates the text to the boolean value.  This works great if the grid is in edit mode, but as soon as I set the behavior for CellEditing to be "false" or set the column editing setting to be "readonly" - the value shown in the column is reverted back to "true" and "false".  Is there a way to get the text value for the associated boolean value to show up instead?
Currently I am using infragistics 14.1 and the control is the WebDataGrid.
