25
Exporting a WebGrid with a hyperlink column does not export the hyperlink into Excel
We are using Version 8.1.20081.2013 CLR 2 with asp.net.  We have a UltraWebGrid that has the first column (a primary key) as a URL/Hyperlink:
    protected void uwg_InitializeRow(object sender, RowEventArgs e)
    { UltraGridCell refNbr = e.Row.Cells.FromKey("PrimaryKey");
       refNbr.Column.Type = ColumnType.HyperLink;
       refNbr.TargetURL = string.Format("@{0}/FormX.aspx?PrimaryKey={1}", Request.ApplicationPath.TrimEnd('/'), refNbr.Value);
       refNbr.AllowEditing = AllowEditing.No;
The hyperlink displays and works correclty in the grid.  But when exporting to Excel via UltraWebGridExcelExporter, the hyperlink column does not work as a hyperlink...it is simply underlined and colored blue...but it is not a hyperlink.
Is there a way for a hyperlink column in an UltraWebGrid to be exported as an Excel formatted hyperlink when using the  UltraWebGridExcelExporter?
Thanks!
