Hi again,
Just realised that when using the Windows7 theme, with the following properties on the WebTab:
The height of the first tab you click on after loading is not set correctly. The data is loaded, however the Tab height is too short to display it all. Clicking on another tab, then clicking back, fixes it.
This doesn't happen with the Office2007Black style, so there must be something in the css doing this. I've compared the two webtab css files, but can't see anything that would cause this. Any suggestions?
Edit: this also happens with ElectricBlue and Default.
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
Hello Alex,
Thank you for posting in the Infragistics community !
I guess you have tried to upload a screenshot image with the properties but this failed. Please put the file in a zip archive and try to upload it once again. It would be also helpful to clarify if you are using the latest 14.2 version and if you experience this issue under all browsers.
