Hi
Help me please in knowing how we can text wrap the slider tick label text.
thanks
Manish Kumar
Hello Manish,
Have you been able to resolve your issue? If you need further assistance, please let me know.
Tsanna
Hi Manish,
Please try to set CssClass property to the WebSlider ValueLabel and apply word-wrap css rule, for instance: this.WebSlider1.ValueLabel.CssClass = "LabelStyle";
<style>
.LabelStyle{
word-wrap: break-word;
white-space: normal;
</style>
I hope this helps.
Hi Tsanna ,
Actually I am using webslider control in our application and the value type of Ticks I am using are of Text type. ie I am putting text in the tick value label which can be of length upto 100 characters. so the two consecutive ticks label are getting overlap to each other, So i wanted to know if there is any work around available so that i may wrap up text to the new line just below it from where its text start
Maniish Kumar.
Have you been able to resolve your issue? If I can provide further assistance, please let me know.
Did you take a look at the online samples about WebSlider: http://ko.infragistics.com/samples/aspnet/slider/configuring-tickmarks-and-labels
Here is also some useful links from the WebSlider documentation:
http://help.infragistics.com/Help/Doc/ASPNET/2014.1/CLR4.0/html/WebSlider_Set_the_Values_Type.html
http://help.infragistics.com/Help/Doc/ASPNET/2014.1/CLR4.0/html/WebSlider_Display_Custom_Formatted_Values.html
If you have further questions, please let me know.
