655
Error Creating Control - WebDropDown (The ConnectionString property has not been initialized)
Hi, I am trying out the WebhierarchicalDataGrid as a templated control in the WebDropDown. I have followed this tutorial http://help.infragistics.com/Help/Doc/ASPNET/2011.2/CLR4.0/html/WebDropDown_Create_a_Multi_Column_WebDropDown_using_Templates.html replacing the WebDataGrid with the WebHierarchicalDataGrid. Everything works fine except when I close the template editing on the WebDropDown the WebDropDown does not render in Design view. It says Error Creating Control - WebDropDown (The ConnectionString property has not been initialized). I am then unable to access the smart tag for the control and therefore unable to edit the control through the GUI. Below is an example of this issue.
<%@ Page Language="VB" AutoEventWireup="false" CodeFile="Default5.aspx.vb" Inherits="Default5" %>
<%@ Register Assembly="Infragistics4.Web.v14.2, Version=14.2.20142.2146, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
Namespace="Infragistics.Web.UI" TagPrefix="ig" %>
Namespace="Infragistics.Web.UI.ListControls" TagPrefix="ig" %>
Namespace="Infragistics.Web.UI.GridControls" TagPrefix="ig" %>
Namespace="Infragistics.Web.UI.DataSourceControls" TagPrefix="ig" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
<title></title>
</head>
<body>
<form id="form1" runat="server">
<div>
<ig:WebScriptManager ID="WebScriptManager1" runat="server">
</ig:WebScriptManager>
</div>
<ig:WebDropDown ID="WebDropDown2" runat="server" Width="200px">
<Items>
<ig:DropDownItem Selected="False" Text="Products" Value="">
<Template>
<ig:WebHierarchicalDataGrid ID="WebHierarchicalDataGrid1" runat="server" AutoGenerateBands="False"
AutoGenerateColumns="False" DataMember="SqlDataSource1_DefaultView" DataSourceID="WebHierarchicalDataSource1"
Height="350px" Key="SqlDataSource1_DefaultView" Width="400px">
<Columns>
<ig:BoundDataField DataFieldName="ProductID" Key="ProductID">
<Header Text="ProductID" />
</ig:BoundDataField>
<ig:BoundDataField DataFieldName="ProductName" Key="ProductName">
<Header Text="ProductName" />
<ig:BoundDataField DataFieldName="SupplierID" Key="SupplierID">
<Header Text="SupplierID" />
<ig:BoundDataField DataFieldName="CategoryID" Key="CategoryID">
<Header Text="CategoryID" />
<ig:BoundDataField DataFieldName="QuantityPerUnit" Key="QuantityPerUnit">
<Header Text="QuantityPerUnit" />
<ig:BoundDataField DataFieldName="UnitPrice" Key="UnitPrice">
<Header Text="UnitPrice" />
<ig:BoundDataField DataFieldName="UnitsInStock" Key="UnitsInStock">
<Header Text="UnitsInStock" />
<ig:BoundDataField DataFieldName="UnitsOnOrder" Key="UnitsOnOrder">
<Header Text="UnitsOnOrder" />
<ig:BoundDataField DataFieldName="ReorderLevel" Key="ReorderLevel">
<Header Text="ReorderLevel" />
<ig:BoundCheckBoxField DataFieldName="Discontinued" Key="Discontinued">
<Header Text="Discontinued" />
</ig:BoundCheckBoxField>
</Columns>
<Behaviors>
<ig:Selection CellClickAction="Row" RowSelectType="Single">
</ig:Selection>
</Behaviors>
</ig:WebHierarchicalDataGrid>
<ig:WebHierarchicalDataSource ID="WebHierarchicalDataSource1" runat="server">
<DataViews>
<ig:DataView ID="SqlDataSource1_DefaultView" DataMember="DefaultView" DataSourceID="SqlDataSource1" />
</DataViews>
</ig:WebHierarchicalDataSource>
<asp:SqlDataSource ID="SqlDataSource1" runat="server" ConnectionString="<%$ ConnectionStrings:NorthwindConnectionString %>"
SelectCommand="SELECT * FROM [Products]"></asp:SqlDataSource>
</Template>
</ig:DropDownItem>
</Items>
</ig:WebDropDown>
</form>
</body>
</html>
  • 20255
    Verified Answer
    Thank you for your question, this is happening because you've put the data sources definitions into the item template. Put them after the WebDropDown definition and the GUI will be available again.
    Code snippet:
    1.                                 <Behaviors>
    2.                                     <ig:Selection CellClickAction="Row" RowSelectType="Single">
    3.                                     </ig:Selection>
    4.                                 </Behaviors>
    5.                             </ig:WebHierarchicalDataGrid>
    6.
    7.                         </Template>
    8.                     </ig:DropDownItem>
    9.                 </Items>
    10.             </ig:WebDropDown>
    11.
    12.             <ig:WebHierarchicalDataSource ID="WebHierarchicalDataSource1" runat="server">
    13.                 <DataViews>
    14.                     <ig:DataView ID="SqlDataSource1_DefaultView" DataMember="DefaultView" DataSourceID="SqlDataSource1" />
    15.                 </DataViews>
    16.             </ig:WebHierarchicalDataSource>
    17.             <asp:SqlDataSource ID="SqlDataSource1" runat="server" ConnectionString="<%$ ConnectionStrings:ConnectionString %>"
    18.                 SelectCommand="SELECT * FROM [Products]" ProviderName="<%$ ConnectionStrings:ConnectionString.ProviderName %>"></asp:SqlDataSource>
    19.         </div>
    20.     </form>
    21. </body>
    22. </html>
    Let me know if I may be of further assistance.
