Hi, we are working in a WebDataGrid and need a column to be DateTime format. So we setup a DatePickerProvider in that column with no result. When the grid is rendered it appears a "calendar icon" in that cell (we are using Adding Behavior) but when I click in that icon nothing happens.
My markup have the declaration of the Editor Provider, and in code behind I associated to column:RowAddingColumnSetting config = new RowAddingColumnSetting();config.ColumnKey = "Date";config.EditorID = "dppDate";config.ReadOnly = false;wdg.Behaviors.EditingCore.Behaviors.RowAdding.ColumnSettings.Add(config);
I dont know if I'm missing some attributes or something related? Can you help me?
I want to display date and time using date picker, so how can i do it. please help me.
I am glad that I've managed to help you.
Hi, thanks for your reply.
This workaround is working for me
Thank you for reporting this.
I can suggest you a quick and easy workaround for this. You can just add WebMonthCalendar control into your page and associate it to the EditorControl of the DatePickerProvider.
Code snippet:
Let me know if I may be of further assistance.
I didnt notice any difference between your attached example and my code. So, I did some extra research and I discovered a major problem!
First of all, We are using IG v. 14.2.20142.1028.
If I include a dummy text from code behind in a server tag, calendar editor stop working:
Markup Code:...<body> <form id="form1" runat="server"> <div> <asp:ScriptManager ID="ScriptManager1" runat="server"></asp:ScriptManager> <h1><%=GenerateString() %></h1> <ig:WebDataGrid ID="WebDataGrid1" runat="server" Width="800px" AutoGenerateColumns="False" DataSourceID="SqlDataSource1" DataKeyFields="OrderID">......
Code Behind: public string GenerateString() { // Just generating a dummy text. return "Welcome back!"; }
We need you to validate this behavior and provide Us with a solution please. This seems to have no sense for Us.
I am attaching .aspx and aspx.cs files, you can use your example and just replace that 2 files.
Thanks.
