I am using Infragistics 14.1, in my case i would like use WebNumericEditor to input value without comma also set the max value to avoid large than int32.
I had reference the below link, change the Culture property, it is work about remove comma but no max value.
http://ko.infragistics.com/community/forums/t/21058.aspx
Is there any suggestion about this problem?
Thanks.
KC
Hello Ivaylo,
That's a simple solution, I can't believe I have overlooked this property. Thank you for your help.
Hello KC Cheung,
It is possible to set MinValue as well as MaxValue for the numeric editor.
For example here is an online sample, where the min and max are for a NumericEditor are specified by another two editors. In this sample by default the Editor limited by Range is loaded with a MinValue of 0 and MaxValue of 10.
You could set this property in Markup, CodeBehind as well as ClientSide:
In Markup it could look like: <ig:WebNumericEditor ID="WebNumericEditor1" runat="server" MaxValue="10"></ig:WebNumericEditor>
In CodeBehind:WebNumericEditor1.MaxValue = 10;
It is also possible to set this maxValue using ClientSide. For example, handling Initialize client event:In order to set the needed properties in Client-Side you can use the built-in functions for the “WebNumericEditor” like this:
function WebNumericEditor1_Initialize(sender, eventArgs){sender.set_minValue(5); // set min valuesender.set_maxValue(20); // set max value}
What is more, you could find these properties under the official documentation - WebNumericEditor Class Members.
