Hi, I have a problem with webdatagrid when pressing enter key in a disabled column. I need grid events (as Row Adding) to be fired whenpressing enter key in a disabled column, but instead that, the next control event is fired (like button click for example).
Hello Edward,
Thank you for getting back to me, I am glad to hear that.
Hi, thanks for your reply, I applied a workaround, that works for me
Let me know if I may be of further assistance.
Maybe you are setting DefaultButton attribute of your asp form?
If I have a button on my page and hit enter, nothing happens.
Hi, in fact that code works for commiting the row, but that is not the problem.If you test your code in the txt you receive the message: "Response from button..." when commiting the row.It means that the button events (client side and server side) are fired.
I need to avoid others controls events to be fired when press the enter key in a disabled column in WDG.
