I'm having problems with the WebDataGrid and WebDatePicker controls. In WebDataGrid I couldnt find out what I need to do to set grid's language to SPANISH (I want filters, date, etc, displays in SPANISH formats). In the WebDatePicker y set de Culture property to "es-ES" and it works perfect but, if I put both controls in the same page, I received the error "Specified cast is not valid".
This problem comes when I tried to put date data into a column that has a template that format that data to dd/MM/yyyy for example.
I will appreciate anything you could provide me.
Thanks a lot,
Gustavo.-
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
Hello Gustavo,
There should be both a WebDataGridStrings.resx and a WebDataGridStrings_runtime.resx files. I believe there should be strings to localize in both of the files,, so do not hesitate to follow the steps provided for both of the files.
Hristo, thanks a lot again. I have a question:
The word wizard that you send me say that I need WebDataGridStrings.resx but the strings that I need to change are on WebDataGridStrings_runtime.resx. The steps are the same as are described ???
For example, I need to translate:
I will be waiting your response before do anything wrong.
Regarding displayed messages of grid on filtering and etc - this is not supported out of the box but can be implemented by customizing the WebDataGridStrings.resex file. A detailed explanation on how to do this can be found at
WebDataGrid Localization.zip
This is also discussed in the following threads:
http://ko.infragistics.com/community/forums/p/24594/90382.aspx
http://ko.infragistics.com/community/forums/t/52390.aspx
http://ko.infragistics.com/community/forums/t/83662.aspx
Please let me know if you have further questions on the matter.
Hristo,
Your solution works perfect with format troubles but the filters of the grid still are in english ...
Do you know how can I set the language of the filters options or any displayed message inside the grid ??
gustavo.-
