I am trying to add Infragistics (v14.2) controls into a ASP.Net (4.5) web application. I installed Infragistics v14.2 on my machine and installation was successfull.
I am using VS 2012 on Windows 8.1.
I can add the controls with 'Default' styles. But I want to try other support themes by Infragistics. For that I tried to add 'Application Styling Configuration Dialog' add-in to VS. It gave me the following error.
---------------------------The Add-in 'Application Styling Configuration Dialog' failed to load or caused an exception.Would you like to remove this Add-in?If you choose yes, the file it was loaded from, 'C:\Users\upekha\Documents\Visual Studio 2012\Addins\Infragistics.Web.ApplicationStylingConfiguration.AddIn', will be renamed.
Error Message: <Unknown Error>Error number: 80131522---------------------------
AddIn files and the DLL are available in the specified location. I looked into addIn XML(s) and it refers to the correct DLL.
Infragistics2.Web.ApplicationStylingConfiguration.v14.2.dll Infragistics.Web.AppStyling.Connect2_142
Please help to add this tool to VS in order to change application styling OR else suggest me a way to change 'Default' application styles and use other themes for styling.
Thanks in advance
Thank you for your feedback. Please let me know if I may be of any further assistance to you.
Thank you for your response.
I tried option 1 and it didn't work for me.
But the second option worked for me.
Thanks!
Thank you for posting in the Infragistics community !
Please remove the files and then try to manually install as follows:
1) copy the contents of the "[INSTALL_DIRECTORY]/ASP.NET/Application Styling Configuration" folder into your "%USERPROFILE%/My Documents/Visual Studio 2012/Addins
Visual Studio should detect the new add-in descriptor file's presence automatically.
Otherwise you can change the style theme from the web.config file as follows:
<infragistics.web enableAppStyling="true" styleSetName="Office2007Black" styleSetPath="~/ig_res/" />
infragistics.web
enableAppStyling
true
styleSetName
Office2007Black
styleSetPath
~/ig_res/
You can refer for more details at
http://ko.infragistics.com/help/aspnet/web_enabling_application_styling_using_the_web_config_file.html
