<ig:TemplateDataField Key="ActionKey" Header-Text="Actions" Width="11%"> <ItemTemplate> <div class="igg_wordWrapp" style="width: 98%; float: left"> <asp:LinkButton runat="server" CssClass="Hover" Font-Bold="true" ID="lnkBtnVendor" Text='Record Quatation' /> <asp:LinkButton runat="server" CssClass="Hover" Font-Bold="true" ID="LinkButton1" Text='Compare' /> </div> </ItemTemplate> </ig:TemplateDataField> </Columns> <Bands> <ig:Band DataMember="dvVendors" DataKeyFields="Id" AutoGenerateColumns="false"> <Columns> <ig:TemplateDataField Key="Check" Width="20px"> <ItemTemplate> <div style="margin-left: -5px"> <asp:CheckBox ID="chkVendor" runat="server" CssClass="checkbox-style" Checked="true" onClick="chkItemChekBoxClick();" /> </div> </ItemTemplate> <HeaderTemplate> <div style="margin-left: -5px"> <input type="checkbox" checked="true" style="display: block" class="checkbox-style" onclick="chkHeaderCheckBoxClick(event);" /> <asp:LinkButton runat="server" CssClass="Hover" Font-Bold="true" ID="lnkBtnVendor12334" Text='<%#Eval("how to access some values from parent row")%>' /> </div> </HeaderTemplate> </ig:TemplateDataField> <ig:TemplateDataField Key="SerialNo" Width="20px"> <ItemTemplate>
i don't know anything pls help :)
I am glad that I've managed to help you.
Tks for your valuable effort. :)
Hello Vishnu,
As I can see from the provided code snippet, you are using HeaderTemplate in order to set a checkbox in the header. Unfortunately it is not possible to access the Parent row from the HeaderTemplate, this could be done within the ItemTemplate though, with this line of code:
((Infragistics.Web.UI.GridControls.GridRecord)(((Infragistics.Web.UI.GridControls.ContainerGridRecordCollection)((((Infragistics.Web.UI.GridControls.GridRecordItem)(((Infragistics.Web.UI.TemplateContainer)(container)).Item)).Record).Owner)).ControlMain.ParentRow)).Items[1].Text
This is because from the child ItemTemplate field the Parent Record can be accessed, although through the HeaderTemplate such access do not exist. I have attached a sample for you in order to show you this approach.
tks for your kind attention.
I just want to know how to give dynamic values to the sub grids header components. In case of previous attachment i want to give a particular column value to the header check box in sub grid.
I am Looking forward to your reply.
