<ig:DropDownProvider ID="UOM_DropDownProvider"> <EditorControl DropDownContainerMaxHeight="200px" EnableAnimations="False" ID="EditorControl" runat="server" EnableDropDownAsChild="False" DropDownContainerWidth="150px"> <Items> <ig:DropDownItem Key="Kgs" Text="Kgs" Value="1"> </ig:DropDownItem> <ig:DropDownItem Key="Liters" Text="Lts" Value="2"> </ig:DropDownItem> <ig:DropDownItem Key="Meeters" Text="Mtls" Value="3"> </ig:DropDownItem> </Items> </EditorControl> </ig:DropDownProvider>
<ig:BoundDataField DataFieldName="ItemPriority" Key="ItemPriorityKey" Width="7%"> <Header Text="Priority" /> </ig:BoundDataField>
<ig:BoundDataField DataFieldName="RemarksTooltip" Key="RemarksKey"> <Header Text="Remarks" /> </ig:BoundDataField> <ig:UnboundCheckBoxField Key="testKey" HeaderCheckBoxMode="BiState" HeaderChecked="true" /> <ig:TemplateDataField Key="ViewKey" Header-Text="View"> <ItemTemplate > <div id="javawwwww" style="width: 99%; float: left"> <asp:LinkButton CssClass="editDoc-button" OnClick="BtnPRItemViewDoc_Click" TabIndex="112" Visible='<%#Eval("HasDoc")%>' ToolTip="Click to view documents" CommandArgument='<%#Eval("Id")%>' runat="server"></asp:LinkButton> </div> </ItemTemplate> </ig:TemplateDataField> <ig:BoundDataField DataFieldName="Id" Key="Id" Hidden="true"> </ig:BoundDataField> </Columns>
<ig:EditingColumnSetting ColumnKey="ItemPriorityKey" EditorID="WebDataGrid1_DropDownProvider1" ReadOnly="False" /> <ig:EditingColumnSetting ColumnKey="RemarksKey" ReadOnly="True" /> </ColumnSettings>
on 'edit any field and post back' above code trigger following error :(
Multiple controls with the same ID 'it11_0' were found. FindControl requires that controls have unique IDs.
if i don't use any TemplateDataField it working fine
any workaround for solving this issue?
Hello Vishnu,
Which is the the code that produces this error and which control do you try to access via FindControl ? Please provide these answers and I will be happy to suggest accordingly.
hi thanks for your quick response :)
error happen when ever adding following code to the webDataGrid
<EditorProviders><ig:DropDownProvider ID="UOM_DropDownProvider"> <EditorControl DropDownContainerMaxHeight="200px" EnableAnimations="False" ID="EditorControl" runat="server" EnableDropDownAsChild="False" DropDownContainerWidth="150px"> <Items> <ig:DropDownItem Key="Kgs" Text="Kgs" Value="1"> </ig:DropDownItem> <ig:DropDownItem Key="Liters" Text="Lts" Value="2"> </ig:DropDownItem> <ig:DropDownItem Key="Meeters" Text="Mtls" Value="3"> </ig:DropDownItem> </Items> </EditorControl> </ig:DropDownProvider> </EditorProviders>
....... then edit any editable cell
then click on any button placed in TemplateDataField.
i think its not happen in user code.
Hi Vishnu,
2260 is not a public build, but 2257 is and it should be available for download for you, after you login to Infragistics website and go to https://ko.infragistics.com/my-account/keys-and-downloads
If you are still not able to download it please let me know and I will provide an alternate link for you.
Hi Hristo,
Thanks for the quik replay. i already tried with version 2257. sadly its not fixed in 2257 :(
It seemed I had a typo in the version number, it must be 2247. I tested with it and am not able to reproduce the issue as with 1005. Could you confirm what is exact version that is available for you in Infragistics website so I can also reassure my findings ?
i tried with 2012 vol 2 (Infragistics4.Web.v12.2, Version=12.2.20122.2257) and that's not working. actually i need the 2012 vol 1 but currently its not showing in my subscription.
any way am going to contact with sales team after that i can able to confirm. Do you please specify extract version that's work fine and available to the public?
Thanks and regards
Vishnu Prasad
This is strange - I was able to reproduce the same with 1005, but am not able to reproduce it with any other version, including 12.2.20122.2257.
Anyway, I have opened a new support case for you with id of CAS-156159-W2R8G8, where I have provided you with a link to download version 12.1.20121.2209 according to your request. You can find your active cases under Account - Support Activity in our website. Please install the provided version and let me know if this fixes your issue.
