Hi Team,
I am working in a migration project where code is getting migrated from Infragistics 2011 to 2014. Hence UltraWebGrid is getting converted to WebDatagrid.
Sharing the code snippet here where on InitializeLayout of a grid, columns are getting added via c# code..
So in InitializeLayout following line is getting called:
uwGridShutDown.Columns.Add(...) and based on the nature of desired column, the one of below function gets called..
How can I do this in webdatagrid where I can add any type of available controls from c#.. Please refer the code below..
Regards
Varun
protected Infragistics.WebUI.UltraWebGrid.UltraGridColumn AddColumn(string baseColumnName, string caption, HorizontalAlign align, bool hidden, bool allowUpdate, bool isBound, string format,double width) { Infragistics.WebUI.UltraWebGrid.UltraGridColumn ugColumn = new Infragistics.WebUI.UltraWebGrid.UltraGridColumn(); ugColumn.BaseColumnName = baseColumnName; ugColumn.Header.Caption = caption; ugColumn.CellStyle.HorizontalAlign = align; ugColumn.Hidden = hidden; ugColumn.Key = caption; ugColumn.AllowUpdate = (allowUpdate) ? Infragistics.WebUI.UltraWebGrid.AllowUpdate.Yes : Infragistics.WebUI.UltraWebGrid.AllowUpdate.No; ugColumn.IsBound = isBound; if (width > 0) ugColumn.Width = Unit.Parse(width.ToString()+"em"); if (!allowUpdate) ugColumn.CellStyle.BackColor = System.Drawing.Color.WhiteSmoke;
if (format != "") ugColumn.Format = format;
return ugColumn; } protected Infragistics.WebUI.UltraWebGrid.UltraGridColumn AddCheckBoxColumn(string baseColumnName, string caption, HorizontalAlign align, bool hidden, bool allowUpdate, bool isBound, string format, double width) { Infragistics.WebUI.UltraWebGrid.UltraGridColumn ugColumn = new Infragistics.WebUI.UltraWebGrid.UltraGridColumn();
ugColumn.BaseColumnName = baseColumnName; ugColumn.Header.Caption = caption; ugColumn.CellStyle.HorizontalAlign = align; ugColumn.Hidden = hidden; ugColumn.Type = Infragistics.WebUI.UltraWebGrid.ColumnType.CheckBox; ugColumn.Key = caption; ugColumn.AllowUpdate = (allowUpdate) ? Infragistics.WebUI.UltraWebGrid.AllowUpdate.Yes : Infragistics.WebUI.UltraWebGrid.AllowUpdate.No; ugColumn.IsBound = isBound; if (width > 0) ugColumn.Width = Unit.Parse(width.ToString() + "em"); if (!allowUpdate) ugColumn.CellStyle.BackColor = System.Drawing.Color.WhiteSmoke; if (format != "") ugColumn.Format = format;
return ugColumn; }
protected Infragistics.WebUI.UltraWebGrid.UltraGridColumn AddButtonColumn(string baseColumnName, string caption, HorizontalAlign align, bool hidden, bool allowUpdate, bool isBound, string format, double width) { Infragistics.WebUI.UltraWebGrid.UltraGridColumn ugColumn = new Infragistics.WebUI.UltraWebGrid.UltraGridColumn();
ugColumn.BaseColumnName = baseColumnName; ugColumn.Header.Caption = caption; ugColumn.CellStyle.HorizontalAlign = align; ugColumn.Hidden = hidden; ugColumn.Type = Infragistics.WebUI.UltraWebGrid.ColumnType.Button; ugColumn.Key = caption; ugColumn.AllowUpdate = (allowUpdate) ? Infragistics.WebUI.UltraWebGrid.AllowUpdate.Yes : Infragistics.WebUI.UltraWebGrid.AllowUpdate.No; ugColumn.IsBound = isBound; if (width > 0) ugColumn.Width = Unit.Parse(width.ToString() + "em"); if (!allowUpdate) ugColumn.CellStyle.BackColor = System.Drawing.Color.WhiteSmoke;
protected Infragistics.WebUI.UltraWebGrid.UltraGridColumn AddWebComboColumn(string baseColumnName, string caption, HorizontalAlign align, bool hidden, bool allowUpdate, bool isBound, string format, string editorControlID, double width) { Infragistics.WebUI.UltraWebGrid.UltraGridColumn ugColumn = new Infragistics.WebUI.UltraWebGrid.UltraGridColumn();
ugColumn.BaseColumnName = baseColumnName; ugColumn.Header.Caption = caption; ugColumn.CellStyle.HorizontalAlign = align; ugColumn.Hidden = hidden; ugColumn.Type = Infragistics.WebUI.UltraWebGrid.ColumnType.Custom; ugColumn.EditorControlID = editorControlID; ugColumn.ValueList.DisplayStyle = Infragistics.WebUI.UltraWebGrid.ValueListDisplayStyle.DisplayText; ugColumn.Key = caption; ugColumn.AllowUpdate = (allowUpdate) ? Infragistics.WebUI.UltraWebGrid.AllowUpdate.Yes : Infragistics.WebUI.UltraWebGrid.AllowUpdate.No; ugColumn.IsBound = isBound; if (width > 0) ugColumn.Width = Unit.Percentage(width); if (!allowUpdate) ugColumn.CellStyle.BackColor = System.Drawing.Color.WhiteSmoke;
Hello Varun,
Please take a look at the following samples:
http://ko.infragistics.com/samples/aspnet/data-grid/using-cell-and-column-templates.
Let me know if it suits your needs.
