865
Help with MarkRecordChange Error
Hi Team,
I have a webdata grid with a bound checkbox coloum (column added to datatable ) and based on selection of checkbox, I am removing the records from the database,
This part is taking place in RowUpdating server side event.
At the end of the rowupdating method, I am re-binding the grid.
Doing so I am getting error ' not set to an instance of an object.",
Below is the detailed stack trace message.
at Infragistics.Web.UI.GridControls.ControlDataRecordCollection.MarkRecordChange(Int32 index)
at Infragistics.Web.UI.GridControls.ControlDataRecord.NotifyPropertyChange()
at Infragistics.Web.UI.GridControls.ControlDataItem.NotifyPropertyChange()
at Infragistics.Web.UI.GridControls.GridRecordItem.set_Text(String value)
at Infragistics.Web.UI.GridControls.EditingCore.OnAction(String actionType, Object id, Object value, Object tag)
at Infragistics.Web.UI.GridControls.GridBehavior.Infragistics.Web.UI.GridControls.IGridBehavior.OnAction(String actionType, Object id, Object value, Object tag)
at Infragistics.Web.UI.GridControls.GridBot.LoadAdditionalClientState(Object state)
at Infragistics.Web.UI.Framework.RunBot.HandleRaisePostDataChangedEvent()
at Infragistics.Web.UI.GridControls.GridBot.HandleRaisePostDataChangedEvent()
at Infragistics.Web.UI.Framework.Data.FlatDataBoundControl.RaisePostDataChangedEvent()
at System.Web.UI.Page.RaiseChangedEvents()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Any idea why I am getting this error
If I need to do so that I need to rebind the grid after rowupdating event that is removing some data from database, how can i do that?
Regards
Varun
