785
Duplicate of DatawebGrid select Row is not Working even I set required properties...(Please provide me a solution and the issue need to delivered today ifself)
Contd.. of this issue. Since the issue got collapsed with someother issue, i am raising as seperate issue. I have answer the questions raised by jason
Are you able to reproduce the behavior you are seeing in this sample? If so, please provide me with the steps that you follow. If not, do you see further differences between my sample and your application?
We have tested in the IE 11 Browser.
The differences between our application vs sample provided
1) Webscriptmanager tag is not present. Please confirm whether we need add that too..
2) ig_res folder is not belongs to version that we are using. I tried that by changing the latest version. If I, the grid styling are different. So it reverted back.
3) In the beheviour section, add more properties that mentioned in the infragistics site.
Which version of the Infragistics product are you using?
Infragistics webdatagrid 13.2.20132.1003
Does this behavior reproduce in a specific browser?
The selection beheviour is not working IE 11
ASPX Page:
<Infragrid:WebDataGrid ID="UserGroupDetails" AutoGenerateColumns="false" runat="server" Width="100%"
OnInitializeRow="UserGroupDetails_InitializeRow" EnableTheming="true" height="230px" EnableDataViewState="true"
EnableAjaxViewState="true" EnableAjax="false"
HeaderCaptionCssClass="removecursor" AjaxIndicator-Enabled="False" >
<Columns>
<Infragrid:TemplateDataField Key="Description" Width="31%" >
<HeaderTemplate>Name</HeaderTemplate>
<ItemTemplate>
<asp:Image ID="UserGroupImage" runat="server" style="float: left;"></asp:Image>
<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "Description")%>
</ItemTemplate>
</Infragrid:TemplateDataField>
<Infragrid:TemplateDataField Width="15%" Key="System">
<ItemTemplate>
<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "System")%>
</ItemTemplate>
<HeaderTemplate>
System
</HeaderTemplate>
<Infragrid:TemplateDataField Width="28%" Key="Email">
<ItemTemplate>
<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "Email")%>
</ItemTemplate>
<HeaderTemplate>
Email Address
</HeaderTemplate>
<Infragrid:TemplateDataField Key="IsUser" Hidden="true">
<ItemTemplate>
</ItemTemplate>
<HeaderTemplate>
IsUser
</HeaderTemplate>
<Infragrid:TemplateDataField Key="UserKey" Hidden="true">
<ItemTemplate>
</ItemTemplate>
<HeaderTemplate>
UserKey
</HeaderTemplate>
<Infragrid:TemplateDataField Key="City" Width="12%">
<ItemTemplate>
<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "City")%>
</ItemTemplate>
<HeaderTemplate>
City
</HeaderTemplate>
<Infragrid:TemplateDataField Key="State" Width="10%">
<ItemTemplate>
<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "State")%>
</ItemTemplate>
<HeaderTemplate>
State
</HeaderTemplate>
</Columns>
<Behaviors>
<Infragrid:Activation Enabled="true" />
<Infragrid:Selection RowSelectType="Multiple" Enabled="true" />
<Infragrid:RowSelectors RowNumbering="false" Enabled="true" />
</Behaviors>
Mani
