330
Version Problem
can i use NetAdvantage for .NET 2007 Vol. 2 CLR 2.0 Ultrawebgrid,NetAdvantage for .NET 2008 Vol. 2 CLR 3.5 Ultrawebgrid in a single aspx page?
 right now i m geeting error. but both are different frameworks is it? then it shouldnt give any error.
  • 19308
    You can not mix and match different versions of the same assembly on the same page.  You especially cannot mix and match different versions of the CLR on the same page, since the type information will all conflict.  Is there a reson you cannot use the server version of the UltraWebGrid?  The grid has remained pretty backwards compatible through the years, and shoulnd't require any changes to go from 7.2 to 8.2.
    Hope this helps,
    -Tony
