I am converting Infragistics 2010 v2 CLR3.5 to Infragistics 2014 v2 using 4.5 CLR using Visual Studio 2013 Professional Update 4. I am getting following error while building the project. Please reply immediately..........
Error 326 'Infragistics.Web.UI.EditorControls.WebNumericEditor' does not contain a definition for 'NegativeForeColor' and no extension method 'NegativeForeColor' accepting a first argument of type 'Infragistics.Web.UI.EditorControls.WebNumericEditor' could be found (are you missing a using directive or an assembly reference?)
This got fixed today. Thanks for your quick response. I appreciate for this.
Please let me know if the suggested helped or if you have other questions on the matter.
Hello Jack,
You can style negative values in WebNumericEditor using the NegativeCssClass property:
wne.NegativeCssClass = "NegativeText";
<style type="text/css"> .NegativeText { color : Red; } </style>
Please let me know if you have other questions
Getting an error in old code which I am trying to convert from WebNumericEdit to WebNumericEditor:
WebTab uwt = (WebTab)sender; foreach (ContentTabItem t in uwt.Tabs) { WebNumericEditor wne = (Infragistics.Web.UI.EditorControls.WebNumericEditor) contentTab.Tabs.FindTabFromKey(t.Key).ContentPane.FindControl("WebNumericEditor" + t.Key); wne.NumberFormat = new System.Globalization.NumberFormatInfo() { NumberGroupSeparator = "" }; wne.NegativeForeColor = Color.Red; wne.CssClass = "";
