480
Strange focus behaviour
I'm using Infragistics4.Web.v12.1 WebDropDown in my application.
There is a strange behaviour with the focus on my jQuery Dialogs. I've set them up to have the "No" option selected by default.
I have overriden the __doPostBack function to show a confirm dialog before actually doing the postback. Everithing works ok when the postback is fired by a standard asp dropdown, but when using the infragistics webdropdown there is something that switches back the focus to the "Yes" button. You can actually see the "No" selected a split second before switching back to "Yes".
Is there something in the WebDropDown messing with the focus?
My page:
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="TestDropDowns.aspx.cs"
Inherits="eRec.Web.UI.TestDropDowns" %>
<%@ Register Assembly="Infragistics4.Web.v12.1, Version=12.1.20121.2072, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
Namespace="Infragistics.Web.UI" TagPrefix="ig" %>
Namespace="Infragistics.Web.UI.ListControls" TagPrefix="ig" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
<link rel="stylesheet" type="text/css" href="styles/jquery/jquery-ui-1.10.3.custom.css" />
<link rel="stylesheet" type="text/css" href="styles/jquery/jquery-ui-1.10.3.custom.min.css" />
<script type="text/javascript" src="scripts/jquery-1.9.1.js"></script>
<script type="text/javascript" src="scripts/jquery-ui-1.10.3.custom.js"></script>
<title></title>
</head>
<body>
<form id="form1" runat="server">
<ig:WebScriptManager ID="WebScriptManager1" runat="server" EnablePageMethods="true" />
<div>
<asp:DropDownList ID="ddtest" runat="server" AutoPostBack="true"
OnSelectedIndexChanged="ddlTest_SelectedIndexChanged">
<asp:ListItem Text="1" Value="1" />
<asp:ListItem Text="2" Value="2" />
</asp:DropDownList>
<ig:WebDropDown ID="wddTest" runat="server" AutoPostBack="true" Width="50px" DropDownContainerWidth="50px"
OnSelectionChanged="wddTest_SelectedIndexChanged">
<Items>
<ig:DropDownItem Text="1" Value="1" />
<ig:DropDownItem Text="2" Value="2" />
</Items>
</ig:WebDropDown>
</div>
<script type="text/javascript" src="TestDropDowns.js"></script>
$(function () {
TestDropDowns.doPostBack();
</script>
</form>
</body>
</html>
My .js:
$.confirm = function (p) {
$(String.format('<div id="sys-message-confirm">{0}</div>', p.message)).dialog({
modal: true,
width: 450,
resizable: false,
title: (p.title) ? p.title : 'message',
buttons: [
text: 'Yes',
click: function () {
if (typeof (p.yesFn) == 'function') {
p.yesFn();
$(this).dialog('close');
text: 'No',
class: 'default-button',
if (typeof (p.noFn) == 'function') {
p.noFn();
open: function () {
$(this).siblings('.ui-dialog-buttonpane').find('button.default-button').focus();
$(this).parent().css({ "z-index": "9999" });
var TestDropDowns = {
postBack: null,
doPostBack: function () {
if (typeof __doPostBack == 'function') {
TestDropDowns.postBack = __doPostBack;
__doPostBack = function (Arg1, Arg2) {
$.confirm({
message: 'Your changes will be lost. Do you want to continue without saving?',
yesFn: function () {
TestDropDowns.postBack(Arg1, Arg2);
noFn: function () {
