I was using "Template" in "WebPanel" in old Infragistics [Infragistics 2010 v2 CLR3.5]
Now I upgraded "WebPanel" to new "WebExplorerBar" using Infragistics 2014 v2 using 4.5 CLR -- and after building and running the project locally, I am getting following error. Let me know the quick fix of "Template" as I don't want to disturb functionality. What tag in place of that can be used.
FYI.....I also tried using <Templates> but it does not work for me.
Error:
[System.Web.HttpParseException] = {"Type 'Infragistics.Web.UI.NavigationControls.WebExplorerBar' does not have a public property named 'Template'."}
Code: (where I am using for your reference - Using "WebExplorerBar" instead of "WebPanel" being used in old project - While upgrading - Template gives error)
<igmisc:WebExplorerBar ID="filterPanel" ExpandEffect="None" ImageDirectory="../images/" Width="100%" runat="server"> <ClientEvents ItemExpanded="ClosePanel"></ClientEvents>
<Template> <asp:Label ID="lblErr" runat="server" ForeColor="red"></asp:Label> <igtbl:WebDataGrid ID="WebDataGrid1" runat="server" Width="100%" ImageDirectory="/ig_common/Images/" CaptionAlign="Top" Height="50px"> <Behaviors> <igtbl:Paging></igtbl:Paging> <igtbl:CellEditing></igtbl:CellEditing> <igtbl:RowSelectors></igtbl:RowSelectors> </Behaviors>
</igtbl:WebDataGrid>
</Template> </igmisc:WebExplorerBar>
I am still following your case. Have you been able to resolve the issue?If you have any concerns or questions, please feel free to contact me, I will be glad to help you.
Thank you for choosing Infragistics components!
Best regards,Nikolay Alipiev
Hello.
Thank you for using our product and I hope that I will be able to help you with my answer.
Here is a sample of how to use Template in the WebExplorerBar.
I'm also attaching a sample, in which I've used your code and put it in a WebExplorerBar. It's not throwing exception. Just please the replace Version=14.2.20142.1 with the version you have installed on your machine.
I will wait for your feedback.
Best regards,
Nikolay Alipiev
